yunloveyou
May 26, 2021Guide
XR500When will the official version of the firmware release
When does your official firmware version released? Currently used 114 firmware, IPV6 has a problem, every time a DHCP to start over, will be dropped
Netduma-Liam
May 27, 2021NetDuma Partner
As above!
It's worth noting that the above firmware is still in beta but it does include fixes that should help with the DHCP issue you're experiencing.
Once installed, I'd suggest factory resetting just to ensure anything low-level is cleared out and you're starting from a clean slate.
- yunloveyouOct 18, 2021Guide
Currently 114 firmware is too bad, after each new operators assign IP, IPV6 will be failure, will have to restart to use, 120 formally when can update firmware version, please?
- Netduma-LiamOct 19, 2021NetDuma Partner
Have you tried the latest beta verison? If not I'd suggest installing it and factory reset after you'd installed it.
