yunloveyou
May 26, 2021Guide
XR500When will the official version of the firmware release
When does your official firmware version released? Currently used 114 firmware, IPV6 has a problem, every time a DHCP to start over, will be dropped
yunloveyou
Oct 18, 2021Guide
Currently 114 firmware is too bad, after each new operators assign IP, IPV6 will be failure, will have to restart to use, 120 formally when can update firmware version, please?
Netduma-Liam
Oct 19, 2021NetDuma Partner
Have you tried the latest beta verison? If not I'd suggest installing it and factory reset after you'd installed it.
