paulebble
Jan 14, 2019Aspirant
XR50AC1900 and a XR500 gaming router0 - PS4 Connection better with ISPs modem/router then XR500
Hi,
Please be patient as I am not too savvy with this technical stuf!!!
I would like to know how to connect my XR500 gaming router to my AC1900 modem/router so they are both under the same name/p...
paulebble
Thanks for the reply. Would the IP address from the NG router be the Gateway IP address?
Jan 14, 2019Guru - Experienced User
no. It will be the IP address the gateway gives the NG router.
- paulebbleJan 15, 2019Aspirant
Sorry for the delay in the reply.
I can't see anything in the settings to allow me to enter the DMZ settings?
My set up: Netgear AC1900 modem/router (wired), Netgear XR500 gaming router (wireless).
- FURRYe38Jan 15, 2019Guru - Experienced User
Check page 189 for DMZ usage on the D7000 modem:
http://www.downloads.netgear.com/files/GDC/D7000/D7000_UM_EN.pdf
