Tierno
Mar 27, 2019Guide
XR700 - Factory resets itself after reboot
Does the XR700 have a self-destruction mode? I'm serious, this thing has been nothing but issues. If anyone can help I would greatly appreciated.
Issues so far in order of appearance: (i upda...
Netduma-Fraser
Mar 28, 2019NetDuma Partner
If the firmware above doesn't work for you I would suggest going to 1.0.1.8.
Make sure you have the router plugged directly into a wall outlet rather than an extender as that could be causing reboots etc if it's not getting the correct power.
Tierno
Apr 10, 2019Guide
Thanks, Fraser. FW 1.0.1.10 seems to be working now. Its a bit sluggish to navigate but thats no biggy. Thanks again!
