Tierno
Mar 27, 2019Guide
XR700 - Factory resets itself after reboot
Does the XR700 have a self-destruction mode? I'm serious, this thing has been nothing but issues. If anyone can help I would greatly appreciated.
Issues so far in order of appearance: (i upda...
Apr 11, 2019Guru - Experienced User
Is Beamforming and MIMO and WMM enabled?
- TiernoApr 11, 2019Guide
Its on auto, ill try to change to manual channels. Yes, apartment building with several wifi neighbors. But this wouldnt happen with my previous router. Yes, on Beamforming and MIMO.
Should i disable 60hz? i dont have any 60hz compatible devices.
Thanks!
- Netduma-FraserApr 11, 2019NetDuma PartnerOkay that could be due to DHCP renewing if so that's normal. Yeah you can turn that off.
- FURRYe38Apr 12, 2019Guru - Experienced User
You can also set the power output level from 100% to 75 or 50 since you have nieghbors near by. This might help. You maybe in a wifi congested area if you live in a apt building.
Thanks!
