Jakuba
Feb 29, 2020Tutor
XR700 - Hybrid VPN - Anti-Bufferbloat
Hello I purchased the XR700 gaming router around 1 month ago. Firmware is the latest one. My Anti-Bufferbloat works fine without VPN added to the router settings. I used DSL reports and other...
Jakuba
Mar 02, 2020Tutor
Hello
I added 2 devices to the VPN.
One is my PC and second is my Xbox One X.
Without VPN added both these devices work with Anti-Bufferbloat showing that its working.
Netduma-Fraser
Mar 02, 2020NetDuma Partner
What are your bandwidth speeds normally/set to and how are you sure it's not working when connected via VPN?
- JakubaMar 03, 2020Tutor
My Bandwidth normally is set to 58.64mb for Download and 17.08mb for Upload.
I then enable Anti-Bufferbloat to 70% Download which gives me 41mb. 70% for Upload which gives me 12MB.
I set it to Always for Anti-Bufferbloat.
I use DSL reports website and use speedtest.net to test it out. And some others also.
Without VPN added the tests on these websites show that they are working for my devices.
When i add VPN the tests show that its not working.
Any other tests i can try?
- Netduma-FraserMar 03, 2020NetDuma PartnerHow have you added the devices to the VPN as it may be the method done which may be incorrect.
- JakubaMar 04, 2020Tutor
After VPN is connected through Hybrid VPN setup.
I click on Add Device underneath where it says VPN Traffic.
I add my PC and Xbox One X as the 2 devices.
