johnfen
May 11, 2025Aspirant
XR700- Manual Firmware update
Hi All, Trying to Manually update the firmware of a XR700 due to DUMAOS not loading error when tyring to access the home page Using a MAC and connected via the ethernet directly to the route...
- May 11, 2025
You won't need to do the TFTP process for this issue, there is also a physical process you need to do to upload via TFTP so the way you're doing it won't work. Go to routerlogin.net/adv_index.htm and that will take you to the Netgear settings part where you can initiate an upgrade.
Netduma-Fraser
May 11, 2025NetDuma Partner
