johnfen
May 11, 2025Aspirant
XR700- Manual Firmware update
Hi All, Trying to Manually update the firmware of a XR700 due to DUMAOS not loading error when tyring to access the home page Using a MAC and connected via the ethernet directly to the route...
- May 11, 2025
You won't need to do the TFTP process for this issue, there is also a physical process you need to do to upload via TFTP so the way you're doing it won't work. Go to routerlogin.net/adv_index.htm and that will take you to the Netgear settings part where you can initiate an upgrade.
johnfen
May 13, 2025Aspirant
yes all loded correctly but the wifi is still not working for some reason, wifi enabled under set up . This was after a power cut at the house, so not sure if its taken something out on the router. Cable connection is ok
