theonlyway
May 07, 2020Aspirant
XR700 & Plex
Hey all,
I thought this was in the manual but cannot find the answer. Does the external drive have to be under a specific size or does that not matter? I thought it had to be under a certain TB and format. Thanks in advance
1 Reply
- Netduma-FraserNetDuma PartnerNot as far as I am aware but double check here to see if you have a confirmed compatible drive - look at XR500 and R9000 https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE
