sovietbarfight
May 26, 2020Follower
XR700 5ghz disconnects everyday at the same time
XR700 5ghz disconnects everyday at the same time. 2.4 Ghz band stays up and the LAN devices stay up. I have changed my channels different than surronding wifi networks. Logs shows nothing and statist...
May 26, 2020Guru - Experienced User
What Firmware version is currently loaded? Try first version of released FW?
Is Smart Connect enabled?
- Netduma-FraserMay 26, 2020NetDuma PartnerDouble check in Advanced WiFi settings as to whether the WiFi has been set to turn off at certain times.
