Retired_Member
Feb 22, 2020XR700 and DUMAOS Limited Functionality
When you are telling people to switch the Device Type in Device Manager: Why would anyone want a super expensive router that cares so much about the device type that it will hang up because of th...
Retired_Member
Feb 22, 2020I rebooted again just now after Device Manager and Network Manager failed to open. I then saw these errors but the apps are working (for now):
[admin login] from source REDACTED, Saturday, February 22, 2020 20:54:13 [DumaOS] Exception caught in 'com.netdumasoftware.autoadmin': ERROR: Exec 'iptables -w -t nat -A exception_output_nat -d 224.0.,.0/4 -j RETURN ' failed with 1 stack traceback: ^I?: in function '__new__' ^I?: in function '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in function <?:223> ^I?: in function '?' ^I?: in function '?' ^I?: in function '?' ^I?: in function '?' ^I?: in function <?:176> ^I[C]: in function 'xpcall' ^I... ^I?: in function '?' ^I?: in function <?:356> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:261> ^I(tail call): ? ^I/dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> ^I[C]: in function 'xpcall' ^I/dumaos/api/cli.lua:59: in main chunk ^I[C]: ? Saturday, February 22, 2020 20:54:13 [DumaOS] Exception caught in cleanup 'com.netdumasoftware.autoadmin': ERROR: Rule not found in chain stack traceback: ^I?: in f,nction '__new__' ^I?: in function '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in main chunk ^I[C]: in function 'require' ^I?: in main chunk ^I[C]: in function 'require' ^I?: in main chunk ^I?: in function <?:261> ^I(tail call): ? ^I/dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> ^I[C]: in function 'xpcall' ^I/dumaos/api/cli.lua:59: in main chunk ^I[C]: ? Saturday, February 22, 2020 20:54:13
- Netduma-FraserFeb 23, 2020NetDuma PartnerUpgrade to this firmware: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix and that should resolve the first part of your concerns. I'd suggest doing a factory reset after the upgrade but considering the reservations you've done then perhaps hold off for now. You can do a backup from Settings > Administration > Backup Settings.
- Retired_MemberFeb 29, 2020
Why would I install this hotfix? First, "beta" is in the title of the zip file and secondly, the release notes for this hotfix only states that it addresses: "Security Advisory for Signed TLS Certificate Private Key Disclosure on Some Routers, PSV-2020-0105"
Where in the release notes does it say it will fix any of the issues I listed?
When will DUMAOS 3.0 be available? I keep seeing its release teased in this forum. Have you all really just stopped worrying about break/fix and shifted your focus onto security concerns or DUMAOS 3.0?
Even Netduma-Fraser said on 2019-11-12: "The 3.0 update includes reworking of existing features which in itself should resolve any current issues."
The angel geek on my right shoulder is telling me to say, "I hope I say all this then find out the 3.0 update is coming out next week." However, the little devil geek on my other sholder who has read through all the issues on these forums is telling me to manage my expectations.
- Netduma-FraserMar 02, 2020NetDuma Partner.22 was a firmware we were providing to people specifically built to fix that issue so .24 will also include this, if you prefer I can give you .22 instead. We like Netgear are not giving out any deadlines/estimations on when the software is being released. We will first be doing a beta which we hope to launch very soon.
