Retired_Member
Feb 22, 2020XR700 and DUMAOS Limited Functionality
When you are telling people to switch the Device Type in Device Manager: Why would anyone want a super expensive router that cares so much about the device type that it will hang up because of th...
Netduma-Fraser
Mar 15, 2020NetDuma Partner
What timeout change are you referring to? Upgrade to this firmware though and that should resolve your issue: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
martyr444
Mar 15, 2020Apprentice
What he was metnioning in the first post above. Not sure ir those will help with the Device Mangager auto timing out or the auto Admin logout but didn't know where or how to set either.
- Netduma-FraserMar 17, 2020NetDuma PartnerUnderstood, you've changed the retry attempts which will allow R-Apps to try loading more often should they fail. That latest update will fix that issue.
