Misterswede
Jan 31, 2020Guide
XR700 and Wi-Fi stops at 15-20mbit
I have 300 mbit down and 150 mbit up when I test via cable all is good, and test directly to fiber router all's is perfect i set up the XR700 not even 1 year old and it tests Wi-Fi and says 300 ...
- Feb 04, 2020
Glad to hear you managed to resolve the issue. I would recommend you take a look at our optimal settings guides. They will help you understand the router and how to use specific features. There are also ? icons on all panels that give you more information as well.
http://support.netduma.com/support/solutions/folders/16000090646
Misterswede
Feb 01, 2020Guide
I found it :-)
The top left corner in QoS there is what down and up are maxed I thing my xr700 had made settings for previous setting
I have put hem both on 1000mbit so it rocks
Design bad from net gear to have so important issue hidden in that small menu
I was about to kill it
Netduma-Fraser
Feb 04, 2020NetDuma Partner
