DarthTom
Nov 05, 2020Follower
XR700 and Wifi Mesh
Hi there, Wanted to know what the best mesh solution will be for my router? Can I use the Nighthawk Mesh Wifi 6 and, more importantly, is there any advantage of going down this route with the rou...
Netduma-Fraser
Nov 06, 2020NetDuma Partner
I don't believe mesh is supported currently. If you need to extra range then an extender may be the best route to go for now.
