DarthTom
Nov 05, 2020Follower
XR700 and Wifi Mesh
Hi there, Wanted to know what the best mesh solution will be for my router? Can I use the Nighthawk Mesh Wifi 6 and, more importantly, is there any advantage of going down this route with the rou...
Nov 08, 2020Guru - Experienced User
You could use either MESH system. However the XRs wifi will not be utilized and need to be turned OFF. I have don't with with my XR router and installed a Orbi AX MESH system in AP mode.
