Yonijo
Jan 03, 2019Tutor
XR700 ans Orange FFTH Fiber
Hello I just buy an XR700 and i try to replace my provider box (Livebox orange) with it On the XR700 there is a specific configuration for this but it doesn’t work. In the last month the provi...
Yonijo
Jan 04, 2019Tutor
Hi
Yes you right XR700 and XR500 are not modem but they are router.
The double hop/nat are not optimize for performance
So i prefere to keep my question.
Maybe you know if is it possible to use ssh/telnet with thoses routers ?
Thks
Thks
Netduma-Fraser
Jan 04, 2019NetDuma Partner
You're usually able to put the ISP hub into modem mode or put the router into it's DMZ, you will not lose performance this way either and will be much easier than what you are trying to achieve as that option is not available but will pass it on to the Netgear team as a request.
