Gardone8876
Mar 11, 2019Guide
Xr700 Bandwidth Allocation QOS
How can I set a device to receive 50mbps? Everytime a new device is added the speed decreases in Bandwidth Allocation. Or do I even need to touch the setting?
- Mar 12, 2019
You got it - we'll work on a 'lock bandwidth' feature to set this in place. Thanks for letting us know you'd like this feature.
Gardone8876
Mar 11, 2019Guide
The percentages keep on decreasing. I found the answer on another thread. The way it works it will keep decreasing the percentage based on devices added. A feature needs to be added to lock the value to a number. Thanks for the help.
- FURRYe38Mar 11, 2019Guru - Experienced User
Thanks for letting us know.
Enjoy.
- Netduma_JackMar 12, 2019NetDuma Partner
- FURRYe38Mar 18, 2019Guru - Experienced User
New FW available:
- Gardone8876Mar 19, 2019GuideThanks for letting me know about the firmware update. I have an android app that notifies me anytime the webpage updates. Keep up the good work. Can't wait to see the feature added.
