vegasranger
Jul 04, 2020Follower
xr700 beeping
The router keeps randomly beeping. between 4 beeps and 8. logs read :[DoS Attack: SYN/ACK Scan] from source: 185.179.202.69, port 27021, Saturday, July 04, 2020 13:56:32 which is the same time...
Netduma-Fraser
Jul 05, 2020NetDuma Partner
I've not heard it beeping before so that's odd, no way to disable that as far as I know. However, if they are lining up with those log entries then disabling the entries should prevent it. Go to Settings > Monitoring > Logs and untick Known DoS attacks and apply. Do the beeps stop then?
