kentgiard
Apr 24, 2022Tutor
XR700 Bricked!
All of a sudden, my router admin page started to display this (on firmware v1.0.1.48) Thinking a factory reset would solve this, I went through the steps and was able to get through the ...
Netduma-Liam
Apr 25, 2022NetDuma Partner
Unfortunately I can't see the image you've pasted as it's not been moderated yet.
Could you please instead try attaching it rather than pasting it in?
- kentgiardApr 25, 2022Tutor
It's just an image of the message "This R-App is not loaded yet, please try again in a minute." (now attached)
Hitting okay refreshes the page and displays the same message.
- Netduma-FraserApr 25, 2022NetDuma PartnerWhen this error occurs, it is almost always resolved by a reboot, so reboot then wait 2 minutes before trying to access and see if it loads then
For sanity sake, I went ahead and powered down the router, waited 2 minutes and then powered it up again. The error still occurs ... but ... it now allows me to connect to the internet. So, progress.
Do you think I should try flashing the firmware again?
