kentgiard
Apr 24, 2022Tutor
XR700 Bricked!
All of a sudden, my router admin page started to display this (on firmware v1.0.1.48) Thinking a factory reset would solve this, I went through the steps and was able to get through the ...
Netduma-Liam
Apr 25, 2022NetDuma Partner
Unfortunately I can't see the image you've pasted as it's not been moderated yet.
Could you please instead try attaching it rather than pasting it in?
kentgiard
Apr 25, 2022Tutor
It's just an image of the message "This R-App is not loaded yet, please try again in a minute." (now attached)
Hitting okay refreshes the page and displays the same message.
- Netduma-FraserApr 25, 2022NetDuma PartnerWhen this error occurs, it is almost always resolved by a reboot, so reboot then wait 2 minutes before trying to access and see if it loads then
- kentgiardApr 25, 2022Tutor
For sanity sake, I went ahead and powered down the router, waited 2 minutes and then powered it up again. The error still occurs ... but ... it now allows me to connect to the internet. So, progress.
Do you think I should try flashing the firmware again?
BTW, is there a way to bypass the initial screen and load the settings page directly?
