kentgiard
Apr 24, 2022Tutor
XR700 Bricked!
All of a sudden, my router admin page started to display this (on firmware v1.0.1.48) Thinking a factory reset would solve this, I went through the steps and was able to get through the ...
kentgiard
Apr 25, 2022Tutor
It's just an image of the message "This R-App is not loaded yet, please try again in a minute." (now attached)
Hitting okay refreshes the page and displays the same message.
Netduma-Fraser
Apr 25, 2022NetDuma Partner
When this error occurs, it is almost always resolved by a reboot, so reboot then wait 2 minutes before trying to access and see if it loads then
- kentgiardApr 25, 2022Tutor
For sanity sake, I went ahead and powered down the router, waited 2 minutes and then powered it up again. The error still occurs ... but ... it now allows me to connect to the internet. So, progress.
Do you think I should try flashing the firmware again?
BTW, is there a way to bypass the initial screen and load the settings page directly?
- Netduma-FraserApr 25, 2022NetDuma PartnerYes there is, go to routerlogin.net/adv_index.htm from there I would concur, try upgrading the firmware again, wait until it is complete (~5 mins), access, reset via the interface, wait 2 minutes and then access and go through setup
