ctwells
Jan 17, 2021Aspirant
XR700 cannot access DumaOS while in AP mode
Main router: wired Ubiquiti EdgeMAX WiFi AP: Nighthawk XR700 Firmware: V1.0.1.20 My current setup is an Ubiquiti EdgeMAX with an ethernet going to an unmanaged switch and another ethernet (also...
Netduma-Fraser
Jan 17, 2021NetDuma Partner
Look at the MAC address of the router on the sticker, then open command prompt and type arp -a find the MAC address of the router and it should show the IP address beside it that you can then use to try and access the interface
- ctwellsJan 17, 2021AspirantThanks, but I know the IP address. It’s reserved on my Ubiquiti and I have confirmed it by verifying the MAC address and also by checking the IP with the Nighthawk app. The problem is that when I type in the XR700’s IP to access DumaOS, I get the ‘connection timed out error’. This did not happen when I used the XR as my router AND WiFi, only after I added the Ubiquiti and changed the XR700 to AP mode.
- Netduma-FraserJan 17, 2021NetDuma PartnerI think you will have to do a factory reset as routerlogin.net should have worked, then, when you go to apply AP mode again select the option to use the fixed IP address and see if it works then.
