CydTulkas
Dec 04, 2020Aspirant
xr700 cannot find Internet through SFP+ port
Hi all, I have recently purchased an XR700 router in the hope of being able to switch the router from the provider. According to my provider I am allowed to use my own router as long as I can con...
CydTulkas
Dec 12, 2020Aspirant
So, new Cisco GLC-BX-U compatible module, no luck. :smileyfrustrated:
It doesn't matter if I use AUTO, or DAC mode, my xr700 does not want to recognize the module. I have tested the new module in the original router and it works like a charm, so it is the correct module.
DOGGAVELI, you mentioned it works for you. What module do you have?
schumaku, the issue seems to have some experience with this issue. Any idea what simplex, Tx1310/Rx1490 module would work in the router? Is it possible that the router is faulty? How could I test that?
Thanks a million.
