Rick6922
Dec 10, 2018Luminary
XR700 causing lag in game on Xbox 1 X
Hi. I just got the NH xr700 set it up, set the geo filter...... I play black ops 4 on Xbox 1X. I never had the game show a conection plug and lag in game before i hooked up the XR700. Can some pls he...
Dec 11, 2018Guru - Experienced User
What FW is currently loaded?
I would do a factory reset on the XR and set it up from scratch. This time, do not set up any QoS or Geo Filter. Use default settings after walking thru the setup wizard.
Connect the xbox via wired connection.
Disable Instant ON on the xbox.
- Rick6922Dec 11, 2018Luminary
Im assuming the FW is the latest. when I plugged up router yesterday it updated.the modem is about a week old and it works great alone. its the netgear CM1000. Ill try what you said. on the xbox what is instanton?
How do I do a factory reset?
- Netduma-FraserDec 11, 2018NetDuma PartnerYou would add it as a game console but no need as DumaOS Classified Games will encompass the console so don't add a manual rule as well.
Xbox Instant On is when you can wake it up from its sleep state and it continues to do downloads in the background. If you turn that off it will turn off the Xbox every time properly and may help with the issue. Factory reset go to Settings > Administration > Backup Settings and click erase.
