Rick6922
Dec 10, 2018Luminary
XR700 causing lag in game on Xbox 1 X
Hi. I just got the NH xr700 set it up, set the geo filter...... I play black ops 4 on Xbox 1X. I never had the game show a conection plug and lag in game before i hooked up the XR700. Can some pls he...
Dec 11, 2018Guru - Experienced User
What FW is currently loaded?
I would do a factory reset on the XR and set it up from scratch. This time, do not set up any QoS or Geo Filter. Use default settings after walking thru the setup wizard.
Connect the xbox via wired connection.
Disable Instant ON on the xbox.
Rick6922
Dec 11, 2018Luminary
Im assuming the FW is the latest. when I plugged up router yesterday it updated.the modem is about a week old and it works great alone. its the netgear CM1000. Ill try what you said. on the xbox what is instanton?
