Rick6922
Dec 10, 2018Luminary
XR700 causing lag in game on Xbox 1 X
Hi. I just got the NH xr700 set it up, set the geo filter...... I play black ops 4 on Xbox 1X. I never had the game show a conection plug and lag in game before i hooked up the XR700. Can some pls he...
Rick6922
Dec 11, 2018Luminary
How do I do a factory reset?
Netduma-Fraser
Dec 11, 2018NetDuma Partner
You would add it as a game console but no need as DumaOS Classified Games will encompass the console so don't add a manual rule as well.
Xbox Instant On is when you can wake it up from its sleep state and it continues to do downloads in the background. If you turn that off it will turn off the Xbox every time properly and may help with the issue. Factory reset go to Settings > Administration > Backup Settings and click erase.
