DayleMaskey
May 20, 2021Aspirant
XR700 Cloud Flush not working
Hey guys! I have an XR700 and cannot get the flush cloud option to work. I get the error "The operation is taking longer than expected. Please briefly wait before using this R-App." I've cleared ...
DayleMaskey
May 21, 2021Aspirant
Thank you for getting back to me Fraser. If this is the case then I'm stuck with another issue. I was trying to use the flush cloud option because I am not able to find any servers all of a sudden. I am playing Halo 5 on Xbox Series X. Until a few days ago the GeoFilter was working perfectly then one afternoon I couldn't get any servers to show up on the map and if I had it on strict I cannot find any games (it will come up saying connecting to dedicated server then boot me} but still nothing coming up on the map. Do you have any suggestions?
Netduma-Liam
May 21, 2021NetDuma Partner
If you fuly zoom out on the Geo-filter map when searching for a game, do you see any 'blocked' icons appearing on the map? I believe there may be an authentication server in Australia that might need to be whitelisted, though your mileage may vary.
If you search for a game without Geo-filter filtering, do you now get in to a game no problem?
