Vazuh
Mar 12, 2019Aspirant
Xr700 connection drop off / disconnects
Having the same issue as everybody else! The newest firmware causes my connection to drop every 20/30 seconds which causes me to get connection interrupted in games. As soon as I change my firmware ...
- Mar 12, 2019
Hello Vazuh - I have sent you a message. Please check your inbox.
~Christian
Netduma-Fraser
Mar 12, 2019NetDuma Partner
I'd suggest you stay on the one you're using at the moment as its stable for you. The team are looking into it so I'm sure they'll provide a fix as soon as they can.
Vazuh
I’ve been told to post on here as there is a beta firmware that will fix the problems as well as having the new features that I’m missing?
- Christian_RMar 12, 2019NETGEAR Employee Retired
~Christian- N4zer0Mar 12, 2019AspirantSame issue but fix by purchasing a sfp modual connecting that to my virgin router , but I really shouldn’t be purchasing another bit of kit to get a £450 router to work on the latest firmware !!!!
- Netduma-FraserMar 12, 2019NetDuma PartnerGlad to hear that resolved your issue. It should be fixable by firmware, perhaps Christian_R can help.
