Vazuh
Mar 12, 2019Aspirant
Xr700 connection drop off / disconnects
Having the same issue as everybody else! The newest firmware causes my connection to drop every 20/30 seconds which causes me to get connection interrupted in games. As soon as I change my firmware ...
- Mar 12, 2019
Hello Vazuh - I have sent you a message. Please check your inbox.
~Christian
Netduma-Fraser
Mar 13, 2019NetDuma Partner
Hi Legendary, the original firmware should resolve the issue you're having but also Christian_R may be able to provide you with a beta firmware that can help.
maidintaiwan
Mar 13, 2019Aspirant
please send me a beta firmware as well.....
- Netduma-FraserMar 14, 2019NetDuma PartnerI've messaged Christian on your behalf maidintaiwan for the firmware.
- FURRYe38Mar 18, 2019Guru - Experienced User
New FW available:
- maidintaiwanMar 22, 2019Aspirant
I am still having the same problem after updated to 1.0.1.10....
and it seems like it got disconnected more frequently than 1.0.1.8
I guess I will try to flash it to 1.0.0.20 for now...
