kdjohnson
Dec 28, 2018Aspirant
XR700 connection to Fios quantum router will not connect to internet
I am trying to attach the Xr700 Router to my verizon quantum router, the router is plugged into Coaxial for internet access. I have tried servral different things suggested on other forums that requ...
- Jan 03, 2019A moca adapter is coaxial to Ethernet and it’s made by actiontec. It’s gonna give you more freedom to place your xr700 any where in your home to get the best results
kdjohnson
Dec 30, 2018Aspirant
I finally was able to access the internet whenI made the router an access point, this seems to limit what I can do with the router now which is not what I wanted. I sitll would like it use the whole functionality of the router but for know at least I have access and at least the wifi is A LOT better then the verizons wifi coverage
Netduma-Fraser
Dec 30, 2018NetDuma Partner
Hi kd, glad to hear that. In that case there shouldn't be anything wrong with the router, switch it back to router mode and do the initial setup.
