kdjohnson
Dec 28, 2018Aspirant
XR700 connection to Fios quantum router will not connect to internet
I am trying to attach the Xr700 Router to my verizon quantum router, the router is plugged into Coaxial for internet access. I have tried servral different things suggested on other forums that requ...
- Jan 03, 2019A moca adapter is coaxial to Ethernet and it’s made by actiontec. It’s gonna give you more freedom to place your xr700 any where in your home to get the best results
Homeslice
Jan 02, 2019Tutor
I have Fios also what I did was give back the router to Verizon brought a moca adapter to send internet to the cable boxes and just used the xr700 router. That way I saved like $15 a month for two years for there equipment. If you need any further information on how to make this possible hit me up
Mjohnson4580
Jan 03, 2019Tutor
I think your best bet would be to run an ethernet cable directly from your ont to the router. You can then bypass the junk verizon gives you. When i had fios at the apartment i lived at that is what i did.
