lkirkland88
Apr 22, 2020Guide
XR700 Constant Issues with DHCP
Running the latest Firmware with the hotfix and still having issues with this router. It refuses to give out IP addresses after a reboot. Devices cant connect due to no IP given. If I set one static ...
BRThompsonator
May 12, 2020Initiate
Same issues - just bought the xr700 - updated firmware to least ( ... .20 I think) - worked great for about a couple hours, then only 10 or so devices would connect, several that had IPs before no longer could get them.
In the meantime, I've had to pull out an old Linksys WRT1200AC to get devices to work correctly again.
- Netduma-FraserMay 13, 2020NetDuma PartnerSorry to hear that, try updating to this firmware and then doing a reset afterwards to ensure there are no legacy issues carried over and see if you get the same issues https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
