lkirkland88
Apr 22, 2020Guide
XR700 Constant Issues with DHCP
Running the latest Firmware with the hotfix and still having issues with this router. It refuses to give out IP addresses after a reboot. Devices cant connect due to no IP given. If I set one static ...
Netduma-Fraser
May 20, 2020NetDuma Partner
Was that upgraded to the .24 version?
Retired_Member
May 20, 2020
.24 solves nothing. It does not change the problem with DumaOS: DHCP / DNS Server is broken, causing R-App(s) and Device Manager to not load as well.
When you actually fix this issue, let me know and I may try to take it out of Access Point mode. Either way, a lot of $$$ spent for just an access point or an inoperable router.
- Netduma-FraserMay 20, 2020NetDuma PartnerEverything in Settings is Netgear, we've already made them aware but if you're still in contact with them let them know you're still encountering the issues.
- Retired_MemberMay 29, 2020
Netgear support feigned ignorance as to what you are saying and wanted to collect more information to send to engineers that I cannot talk to directly. They have no clue how many have returned this router they say. They also say they are not getting many calls about this router. I think the agent is misinformed or trying to mislead. Netduma blames Netgear --> Netgear states they need more info --> Netgear says they have all the info they need, and that they will send a new XR700 --> Netgear sends you "new" XR700 without latest firmware (that way you know they tested it with the latest firmware before sending, right?) --> Same issues arise --> Netgear states they cannot give you a refund, Amazon or wherever you purchased the router has to do that --> Netgear states they cannot give you a newer model, as it is not their policy (What is their recall policy? This thing should be recalled!) --> Netgear states they need more info (logs and more) before they escalate your case to an engineer --> WHEN THIS ROUTER FAILS YOU CANNOT ACCESS IT - IF YOU DO NOT HAVE YOUR LOGS BEING OFFLOADED, HOW WILL ANYONE EVER GET THE INFO THEY NEED?! I pretend to be a sheep on that last statement that just follows the herd, believing that Netgear and Netduma do not know what is going on with this $400 box of ______.
I was able to telnet into the router and run:
tail -f -s 10 /var/log/log-message
I think when this log file is rotated, the tail -f stops reading. tail -F solves this read after log rotation issue in Linux, but it appears that option is not available in BusyBox. Was wondering if this portion of the output I am getting from /var/log/log-message means anything?:
39664:[wifi0] FWLOG: [40638859] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39666:[wifi0] FWLOG: [40640907] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39670:[wifi0] FWLOG: [40645003] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39671:[wifi0] FWLOG: [40646027] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39676:[wifi0] FWLOG: [40651148] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 39677:[wifi0] FWLOG: [40652172] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39684:[wifi0] FWLOG: [40659340] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39690:[wifi0] FWLOG: [40665484] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39691:[wifi0] FWLOG: [40666508] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39693:[wifi0] FWLOG: [40668556] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 ) 39700:[wifi0] FWLOG: [40675724] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39702:[wifi0] FWLOG: [40677772] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x0, 0x0 ) 39704:[wifi0] FWLOG: [40679820] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39706:[wifi0] FWLOG: [40681868] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39707:[wifi0] FWLOG: [40682893] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39712:[wifi0] FWLOG: [40688013] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39713:[wifi0] FWLOG: [40689037] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 39714:[wifi0] FWLOG: [40690061] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39715:[wifi0] FWLOG: [40691085] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39719:[wifi0] FWLOG: [40695181] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39721:[wifi0] FWLOG: [40697229] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39722:[wifi0] FWLOG: [40698253] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39723:[wifi0] FWLOG: [40699277] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39726:[wifi0] FWLOG: [40702349] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39729:[wifi0] FWLOG: [40705421] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39731:[wifi0] FWLOG: [40707469] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 39734:[wifi0] FWLOG: [40710541] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 39747:[wifi0] FWLOG: [40723854] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
I think an endless while loop on the command line may be a workaround for the log file being deleted/recreated (you may get some duplicate info - but at least it is not cutting you off when the log file is cleared/deleted):
root@XR700:/# while true; do date; tail /var/log/log-message; sleep 10; done Fri May 29 09:53:30 UTC 2020 43605:[DumaOS] DHCP new event. 43605:[DumaOS] DHCP lease change. 43605:[DHCP IP: REDACTED][Device Name: REDACTED] to MAC address REDACTED, 43607:[wifi0] FWLOG: [44676614] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43609:[wifi0] FWLOG: [44678662] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43610:[wifi0] FWLOG: [44679687] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43612:[wifi0] FWLOG: [44681735] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43613:[wifi0] FWLOG: [44682759] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43614:[wifi0] FWLOG: [44683783] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43615:[wifi0] FWLOG: [44684807] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:53:40 UTC 2020 43609:[wifi0] FWLOG: [44678662] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43610:[wifi0] FWLOG: [44679687] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43612:[wifi0] FWLOG: [44681735] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43613:[wifi0] FWLOG: [44682759] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43614:[wifi0] FWLOG: [44683783] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43615:[wifi0] FWLOG: [44684807] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43617:[wifi0] FWLOG: [44686855] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43621:[wifi0] FWLOG: [44690951] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43622:[wifi0] FWLOG: [44691975] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43626:[wifi0] FWLOG: [44696071] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:53:50 UTC 2020 43612:[wifi0] FWLOG: [44681735] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43613:[wifi0] FWLOG: [44682759] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43614:[wifi0] FWLOG: [44683783] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43615:[wifi0] FWLOG: [44684807] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43617:[wifi0] FWLOG: [44686855] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43621:[wifi0] FWLOG: [44690951] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43622:[wifi0] FWLOG: [44691975] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43626:[wifi0] FWLOG: [44696071] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43628:[wifi0] FWLOG: [44698119] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43633:[wifi0] FWLOG: [44703239] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:54:00 UTC 2020 43615:[wifi0] FWLOG: [44684807] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43617:[wifi0] FWLOG: [44686855] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43621:[wifi0] FWLOG: [44690951] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43622:[wifi0] FWLOG: [44691975] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43626:[wifi0] FWLOG: [44696071] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43628:[wifi0] FWLOG: [44698119] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43633:[wifi0] FWLOG: [44703239] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43637:[wifi0] FWLOG: [44707335] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43639:[wifi0] FWLOG: [44709383] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43642:[wifi0] FWLOG: [44712455] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:54:10 UTC 2020 43626:[wifi0] FWLOG: [44696071] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43628:[wifi0] FWLOG: [44698119] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43633:[wifi0] FWLOG: [44703239] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43637:[wifi0] FWLOG: [44707335] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43639:[wifi0] FWLOG: [44709383] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43642:[wifi0] FWLOG: [44712455] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43649:[wifi0] FWLOG: [44719624] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43650:[wifi0] FWLOG: [44720648] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43651:[wifi0] FWLOG: [44721672] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43653:[wifi0] FWLOG: [44723720] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:54:20 UTC 2020 43633:[wifi0] FWLOG: [44703239] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43637:[wifi0] FWLOG: [44707335] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43639:[wifi0] FWLOG: [44709383] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43642:[wifi0] FWLOG: [44712455] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43649:[wifi0] FWLOG: [44719624] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43650:[wifi0] FWLOG: [44720648] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43651:[wifi0] FWLOG: [44721672] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43653:[wifi0] FWLOG: [44723720] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43664:[wifi0] FWLOG: [44734984] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43665:[wifi0] FWLOG: [44736008] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:54:30 UTC 2020 43642:[wifi0] FWLOG: [44712455] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43649:[wifi0] FWLOG: [44719624] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43650:[wifi0] FWLOG: [44720648] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43651:[wifi0] FWLOG: [44721672] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43653:[wifi0] FWLOG: [44723720] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43664:[wifi0] FWLOG: [44734984] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43665:[wifi0] FWLOG: [44736008] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43669:[wifi0] FWLOG: [44740105] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43670:[wifi0] FWLOG: [44741128] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43675:[wifi0] FWLOG: [44746249] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:54:40 UTC 2020 43651:[wifi0] FWLOG: [44721672] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43653:[wifi0] FWLOG: [44723720] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43664:[wifi0] FWLOG: [44734984] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43665:[wifi0] FWLOG: [44736008] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43669:[wifi0] FWLOG: [44740105] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43670:[wifi0] FWLOG: [44741128] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43675:[wifi0] FWLOG: [44746249] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43677:[wifi0] FWLOG: [44748297] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43684:[wifi0] FWLOG: [44755465] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43686:[wifi0] FWLOG: [44757513] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) Fri May 29 09:54:50 UTC 2020 43669:[wifi0] FWLOG: [44740105] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43670:[wifi0] FWLOG: [44741128] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43675:[wifi0] FWLOG: [44746249] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43677:[wifi0] FWLOG: [44748297] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43684:[wifi0] FWLOG: [44755465] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43686:[wifi0] FWLOG: [44757513] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43687:[wifi0] FWLOG: [44758537] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43688:[wifi0] FWLOG: [44759561] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43691:[wifi0] FWLOG: [44762633] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43693:[wifi0] FWLOG: [44764681] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:55:00 UTC 2020 43677:[wifi0] FWLOG: [44748297] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43684:[wifi0] FWLOG: [44755465] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43686:[wifi0] FWLOG: [44757513] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43687:[wifi0] FWLOG: [44758537] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43688:[wifi0] FWLOG: [44759561] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43691:[wifi0] FWLOG: [44762633] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43693:[wifi0] FWLOG: [44764681] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43698:[wifi0] FWLOG: [44769801] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43701:[wifi0] FWLOG: [44772874] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43705:[wifi0] FWLOG: [44776969] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:55:10 UTC 2020 43687:[wifi0] FWLOG: [44758537] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43688:[wifi0] FWLOG: [44759561] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43691:[wifi0] FWLOG: [44762633] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43693:[wifi0] FWLOG: [44764681] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43698:[wifi0] FWLOG: [44769801] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43701:[wifi0] FWLOG: [44772874] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43705:[wifi0] FWLOG: [44776969] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43712:[wifi0] FWLOG: [44784138] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43713:[wifi0] FWLOG: [44785162] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43714:[wifi0] FWLOG: [44786186] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:55:20 UTC 2020 43693:[wifi0] FWLOG: [44764681] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43698:[wifi0] FWLOG: [44769801] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43701:[wifi0] FWLOG: [44772874] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43705:[wifi0] FWLOG: [44776969] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43712:[wifi0] FWLOG: [44784138] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43713:[wifi0] FWLOG: [44785162] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43714:[wifi0] FWLOG: [44786186] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43719:[wifi0] FWLOG: [44791306] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43721:[wifi0] FWLOG: [44793354] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43724:[wifi0] FWLOG: [44796426] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) Fri May 29 09:55:30 UTC 2020 43713:[wifi0] FWLOG: [44785162] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43714:[wifi0] FWLOG: [44786186] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43719:[wifi0] FWLOG: [44791306] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43721:[wifi0] FWLOG: [44793354] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43724:[wifi0] FWLOG: [44796426] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43728:[wifi0] FWLOG: [44800522] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43730:[wifi0] FWLOG: [44802570] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43731:[wifi0] FWLOG: [44803594] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43732:[wifi0] FWLOG: [44804618] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43733:[wifi0] FWLOG: [44805642] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) Fri May 29 09:55:40 UTC 2020 43730:[wifi0] FWLOG: [44802570] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43731:[wifi0] FWLOG: [44803594] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 ) 43732:[wifi0] FWLOG: [44804618] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43733:[wifi0] FWLOG: [44805642] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43737:[wifi0] FWLOG: [44809739] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43738:[wifi0] FWLOG: [44810762] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43739:[wifi0] FWLOG: [44811787] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43742:[wifi0] FWLOG: [44814859] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 ) 43745:[wifi0] FWLOG: [44817931] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 ) 43746:[wifi0] FWLOG: [44818955] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x1, 0x0 )
