lkirkland88
Apr 22, 2020Guide
XR700 Constant Issues with DHCP
Running the latest Firmware with the hotfix and still having issues with this router. It refuses to give out IP addresses after a reboot. Devices cant connect due to no IP given. If I set one static ...
Eidolon
Oct 05, 2020Guide
I'm having the exact same issue. The only work around I've found is to edit the lease valid time down to 5 hours or another short length. Most items then will get a DHCP IP address. Once all is working I can change the length back to 24 hours.
I've a mixture of static and virtual. Static will work straight away after reboot but DHCP devices has issues.
- Netduma-FraserOct 06, 2020NetDuma PartnerWhere are you doing this exactly, on the up stream hub? The XR doesn't have the ability to change lease times.
- EidolonOct 06, 2020Guide
Netduma-Fraser wrote:
Where are you doing this exactly, on the up stream hub? The XR doesn't have the ability to change lease times.Hi
I change it when i log on to the router.
You can find it here:
Settings/LAN setup/DHCP Lease Time (range: 1-24 hours)
running version: XR700 V1.0.1.20
Hope that helps
- Netduma-FraserOct 06, 2020NetDuma PartnerAh apologies, was looking at the 500. Glad you have found a semi workaround, NG will have a fix soon and should be in the 3.0 beta.
