lkirkland88
Apr 22, 2020Guide
XR700 Constant Issues with DHCP
Running the latest Firmware with the hotfix and still having issues with this router. It refuses to give out IP addresses after a reboot. Devices cant connect due to no IP given. If I set one static ...
ShadowMelt
Feb 02, 2021Apprentice
Thank you for responding and sending forward the issues
Netduma-Fraser
Feb 04, 2021NetDuma Partner
ShadowMelt just to keep you updated on the situation, they have a potential trial firmware that may fix the issue - they can't just release it though so are looking into a beta forum type deal. Will let you know when I have more info.
- ShadowMeltFeb 04, 2021ApprenticeI will, only can do this kind of troubleshooting on weekends as there is high need for internet during the week.
- serial_killer69Feb 07, 2021Aspirant
Sorry for disapearing, but I gave up and set the XR700 as a simple access point and I'm using my ISP router, and all my issues I've been having with DHCP went away, but now I have a 300€ paper weight being used as access point...
Yes i've done all the troubleshooting in this thread before giving up and yes I've reset to factory settings I don't know how maby times by now....
I will contact Netgear for a RMA if this is not fixed very soon.
- Netduma-FraserFeb 07, 2021NetDuma PartnerThey're working on this for all the routers currently so I expect an update will be out quite soon to resolve this.
What is soon? A week? A month? a year?! Because this thread is almost a year old and we've been reading a promissed updated fix for that long!
When will we have a solid reply?
- Netduma-FraserFeb 07, 2021NetDuma PartnerTake a look in the XR500 beta topic around page 18 onwards and you'll see Timchang the XR500 lead engaging with users on the issue and collecting data on this. It is a Netgear issue but they've already released a beta version that helps with it so once confirmed they can apply it to others.
- ShadowMeltFeb 07, 2021ApprenticeThanks for the info, it means a lot. I know cornovirus all that probably slow things down a ton. Hope we can get this fixed
- serial_killer69Feb 21, 2021Aspirant
Any news on this?!
- Netduma-FraserFeb 21, 2021NetDuma PartnerResults on the XR500 are promising so far so once Tim has confirmed it's working they can port it to the XR700
- ShadowMeltFeb 21, 2021ApprenticeGreat news
- serial_killer69Feb 22, 2021Aspirant
When will that happen?! I only hear empty promises and hopes for months now, and still nothing, this is a 300€ router, not a chinese cheap 30€ one!! This is unaceptable on this level from a reputable company like Netgear!
- Netduma-LiamFeb 22, 2021NetDuma Partner
I understand it's frustrating, we're working as hard as we can to progress this but unfortunately these things take time. I can't really provide an ETA for when this might happen but we'll update the forum the moment we know.
- EidolonFeb 22, 2021Guide
Hi serial_killer69 and anyone else that may find the below useful.
I completely agree with your frustrations and echo them myself. If you have a laptop or PC kicking around, try using Open DHCP. I've been using that for months as a work around and my network hasnt hiccuped since. The thought of using the XR700 as an AP only would drive me nuts, especially as you said it is so expensive.
I've given up on waiting for this to be fixed so i recently purchased a NAS to use for Plex, but it also gives me a DHCP server which hasnt fallen over yet. Even if they supposedly fix it, i dont think i'll trust it to do the job.
With regards to RMA, i purchased my unit 18 months ago so they won't give me a RMA. Good luck if this is the route you take.
Hope the above is useful and if nothing else gives you some ideas as a work around.
- ShadowMeltMar 14, 2021ApprenticeIs there an update to the new firmware?
- Netduma-FraserMar 14, 2021NetDuma PartnerNothing yet, the XR500 potential fix hasn't fixed it for all users so something that still needs to be looked into
- serial_killer69Mar 22, 2021Aspirant
So a few more months has passed and still nothing.... Is that so hard to get people together to fix a MAJOR product flaw?
Netduma-Fraser wrote:
Nothing yet, the XR500 potential fix hasn't fixed it for all users so something that still needs to be looked into - Netduma-LiamMar 22, 2021NetDuma Partner
Apologies for that, we are working on this issue dilligently but unfortunately it's a complicated one. We'll be sure to post here once we have an update.
- ShadowMeltMar 22, 2021ApprenticeI hope so, I'm crossing my fingers. I have been waiting so long
- ShadowMeltMay 13, 2021ApprenticeAny news on this this fix?
- Netduma-FraserMay 14, 2021NetDuma PartnerShadowMelt NG are actively looking into the issue and combing over all the data they have received from the community so I suspect that they will be able to fix this for the next version but I don't have an ETA on that.
- EidolonMay 14, 2021Guide
Hi Netduma
Firstly this is not to you as i know that you have been so very helpful and have kept us all updated. This is feedback to Netgear.
Over a year a go this thred was created and we are told, it will be fixed.
If this was a car, and it couldnt do a fundemental role which is expected of a car, like lock the doors, then it would of been recalled and fixed.
This is a very expensive piece of kit, and it is faulty. It isnt fit for purpose as it doesnt work!
How much longer do we have to wait for a resolution?
From my perspective, we have all been considerate and accepting of the position of Netgear. We have believed the constant "soon" comments. Apart from requesting a RMA, i don't know what else to do.
- RamjetXJun 05, 2021Star
So after a year and a half of issues with the XR700... I've ditched it as the DHCP host on my network.
I've replaced it with a Raspberry Pi 4, running Pihole as a DNS ad blocker and DHCP host all in one. It's only been a day so far, but everything looks to be working. https://www.youtube.com/results?search_query=pihole+dhcp <--- Use some of these videos to learn how
Will keep people updated if I experience any problems... Using this method, I still get to keep the Plex built in on the router and the Pi doesn't add alot to the electric bill.
We shouldn't have to do this. But Netgear and Netduma will never fix the DHCP in their firmware.... and it's becoming quite clear now that they don't know how to fix it.
Ramjet
- ShadowMeltJun 05, 2021ApprenticeIs there any news on this from netgear team?
- Netduma-FraserJun 05, 2021NetDuma PartnerI haven't heard any new news but I'll ask the team and see how they're getting on with it. I assure you they will be fixing this, issues like these are not always clear and can take significant debugging
- EidolonJun 05, 2021Guide
RamjetX wrote:So after a year and a half of issues with the XR700... I've ditched it as the DHCP host on my network.
Ramjet
Ditto. I now use my NAS as DHCP.
