id3athdealer
Apr 07, 2019Follower
XR700 DHCP issues
Hello everyone,
my XR700 router does disconnect the LAN devices after a lease change. I also read the thread about the XR500 with similar DHCP issues and i also have the xbox one x in stand by ...
- Apr 07, 2019Hi Bryan, the instant on issue with the Xbox isn't just exclusive to the NPG routers. Other routers suffer as well and it's something NG are in communication with Xbox over in order to get a fix. Could you turn off instant on mode please and see if it's resolved?
Altsai
Apr 17, 2019NETGEAR Expert
which FW version do you use now? v1.0.1.10 or?
