ShooterStein
Dec 06, 2019Aspirant
XR700 DHCP, No Internet, Dropping Connection, Bad Coverage
I can't tell you how disappointed I am with the XR700. I am not an IT perfessional but this isn't my first rodeo. I have had issues getting DHCP to work correctly. It starts off ok and any little ...
Dec 08, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
JohnnyCo1n5
Dec 08, 2019Star
Check out this pic. This should have tipped us both off. Never Again!
