DavJern73
Jul 05, 2020Guide
XR700 disconnecting in AP mode
Ive always had a 2nd router in AP mode, it was an ASUS...that died ( I Think) and I ended up buying a XR700. I took my old XR500 and made that a AP now. MY son as the AP router in his room that he pl...
DavJern73
Jul 06, 2020Guide
yes, I have it wired with a new cat 8 cable. The cable is about 30 ft but its going under my house so its really only like 10 ft in another room. I disconnected his xbox from the xr500 and connected it to my xr700 last night and he didnt get disconnected once. Im stumped.
Netduma-Fraser
Jul 06, 2020NetDuma Partner
I've just realized you've posted this on the Netduma forum as well, lets continue there as we're helping you in two places at the moment!
https://forum.netduma.com/topic/31704-xr500-disconnecting-in-ap-mode/
- DavJern73Jul 06, 2020Guide
Correct I did...I posted over there but realized since its under netgear over here would be better. I'm not sure if its easier to delete the post over on Duma then here. Sorry.
- Netduma-FraserJul 07, 2020NetDuma PartnerDon't worry about it, if people have the same issue on the NG forum they can see this here and then follow it on the ND forum. We mostly reply to the issues here anyway :)
