XSlashDashX
Feb 09, 2019Tutor
XR700 disconnecting so often
Hello. Just recently purchased this router and noticed that my PC that is hooked up to ethernet cable keeps getting disconnected every
5 or so minutes.
Current firmware version I have is XR700 V1...
Netduma-Fraser
Feb 09, 2019NetDuma Partner
So this is across ALL devices? Upgrade to the latest firmware version and see if that resolves your issues.
XSlashDashX
Feb 09, 2019Tutor
Isn't the firmware I posted the newest?
- Netduma-FraserFeb 09, 2019NetDuma PartnerAh yes, apologies! In that case I would recommend downgrading to this firmware: https://kb.netgear.com/000060213/XR700-Firmware-Version-1-0-0-20 as some people with issues similar to yours have found it doesn't occur on that firmware.
- XSlashDashXFeb 09, 2019Tutor
So far so good. Haven't used it much but played a few rounds of different games and no disconnect yet from downgrading to old firmware. Hoping the new version will have this bug fixed.
- Netduma-FraserFeb 09, 2019NetDuma PartnerGreat to hear that, keep us updated. Yes our teams are looking into it as we speak
