nwreed
Jan 04, 2019Aspirant
XR700 disconnects continuously
Hi all,
I recently purchased a brand new XR700 and it's been a nightmare so far. Setup just fine, auto patched to the latest firmware no problem As soon as I started using it, however, I b...
Netduma-Fraser
Jan 04, 2019NetDuma Partner
As you've found Netgear are aware of the issue and are actively looking into the issue. If the steps which have worked for others are not working for you I'd recommend getting in touch with Netgear support to see if they have any further suggestions http://support.netgear.com/ or can collect data from you to diagnose.
nwreed
Sorry I meant that 45 minutes is the longest my devices have stayed connected. There is no set time limit on when they disconnect. Could be 3 minutes, could be 45 minutes. 45 is just the longest I've had the connection stay stable since I set up the router.
- Netduma-FraserJan 04, 2019NetDuma PartnerThat's very strange, can you include a copy of the logs please when a device disconnects?
