Rick6922
Dec 27, 2018Luminary
Xr700 disconnects from xbox
xr 700 discconecting ,I gettingDHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2...
Dec 27, 2018Guru - Experienced User
What FW is currently loaded?
How is the xbox connected to the router? wired or wireless? Wired is preferred.
Disable "Instant ON" feature on the xbox. This is known to cause problems between xbox and routers.
Set an IP address reservation for the xbox console ON the router.
- Rick6922Dec 27, 2018Luminary
DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DHCP IP: 192.168.1.8][Device Name: XBOXONE] to MAC address 2c:54:91:99:2a:10, Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP lease change., Thursday, December 27, 2018 17:11:07 [DumaOS] DHCP new event., Thursday, December 27, 2018 17:11:07 [DumaOS] No wifi metadata for mac '2c:54:91:99:2a:10', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:16', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:00:00:fb', Thursday, December 27, 2018 17:11:06 [DumaOS] No wifi metadata for mac '01:00:5e:7f:ff:fa', Thursday, December 27, 2018 17:11:06 [DumaOS] Error parsing line in ARP table: 'fe80::f0e2:8d51:dbbf:b5f2 dev br0 lladdr 2c:54:91:99:2a:10 REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1429:d42d:298a:94d4 dev br0 lladdr bc:e1:43:bf:15:3e REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::ce6e:a4ff:fefc:157a dev br0 lladdr cc:6e:a4:fc:15:7a REACHABLE', Thursday, December 27, 2018 17:10:58 [DumaOS] Error parsing line in ARP table: 'fe80::1659:c0ff:fe4d:f3d9 dev br0 FAILED'., Thursday, December 27, 2018 17:10:58 [DumaOS] No wifi metadata f [did you look at the system log where it says ] I'm running new fw, modem is cm1000. i set up a staic ip on xbox. every thing worked fine but i put a new dishwasher in today and flipped the curcuit breaker off to wire it and flipped back on and its disconnecting from xbox. if you look at the system log it says DHCP lease change at the time it logs me out?
- FURRYe38Dec 27, 2018Guru - Experienced User
Remove the static IP address from the xbox and set it for automatic. Set a IP address reservation for the xbox ON the router.
How is the xbox connected? Wired or Wireless?
wired, netduma jack looked at my system log last time and said type in the ip address on the xbox manually, then go to lang in the router and reserve that specific ip address,the xbox had a 8 at the end of the ip address was the only diffrence from my other devices. it worked great for almost 2 weeks that ive had the router untill i flipped my breaker turning the power off to the house and every thing in it.
