Gamer_0224
Nov 12, 2018Tutor
Xr700 disconnects
Cm1000 modem, xr700 router, to Xbox. Using vandesail cat 8 Ethernet. 500 mb down 30 mb up speeds on cable internet. Usually get 600-660 down an 32-40 up. Xbox shows 60-74 latency. Was playing last nig...
- Nov 17, 2018
took out the firmware anbd reloaded it have not had an issue since then. did my best mtu setting had fragmented files after 1400 mtu doing the run-cmd- ping yahoo.com -f -l 1400. then did the +20+8 for a 1428 mtu. after 1400 mtu had framented which sucks; but that is on my isp. Thank you for the fan threshold info did not know about it. set it up where it kicks on here and there. just so it does not sit idle. it does work. BO4 hit detection is still off. been playing with the anti buffer bloat 70% - 40% no difference). have geo at 600 mile from me with 15-33 ping. dsl tests are A with bufferbloat. Have dove dumaos games checked and unchecked. qos to xbox is 70% down and up. upgraded cat cable to cat8 26 awg.
Altsai
Nov 15, 2018NETGEAR Expert
Fan won't be turn on until hitting the turn-on threshold. You can enforce to turn it on via a hidden page.
Gamer_0224
Nov 17, 2018Tutor
- Gamer_0224Nov 17, 2018Tutor
- Netduma-FraserNov 17, 2018NetDuma PartnerCan't see your pictures as they haven't been moderated yet. Great to hear you're not getting that issue anymore. Thats a fantastic ping so will be down to the game at that point.
yes great ping but still need to get with the isp. 16 channels down and 3 channels up is barely running from my isp but is all they support. hit detection is still off been reading through forums to resolve this issue. switched over to my arris sb8200 (from the Netgear cm1000) and wrt3x same issue. Used the xr700 on the sb8200 and seemed better in b04 on xbox one X. just do not like the lag comp they implimented in games now. Seems like it punishes people for good hardware and good ping. Only thing I see is to throttle your internet to barely nothing. I remember in the older days hardware and ping you owned. ethernet cables are 3 feet long. turn off all devices except console. fiber is not offred in my area.
