Gamer_0224
Nov 12, 2018Tutor
Xr700 disconnects
Cm1000 modem, xr700 router, to Xbox. Using vandesail cat 8 Ethernet. 500 mb down 30 mb up speeds on cable internet. Usually get 600-660 down an 32-40 up. Xbox shows 60-74 latency. Was playing last nig...
- Nov 17, 2018
took out the firmware anbd reloaded it have not had an issue since then. did my best mtu setting had fragmented files after 1400 mtu doing the run-cmd- ping yahoo.com -f -l 1400. then did the +20+8 for a 1428 mtu. after 1400 mtu had framented which sucks; but that is on my isp. Thank you for the fan threshold info did not know about it. set it up where it kicks on here and there. just so it does not sit idle. it does work. BO4 hit detection is still off. been playing with the anti buffer bloat 70% - 40% no difference). have geo at 600 mile from me with 15-33 ping. dsl tests are A with bufferbloat. Have dove dumaos games checked and unchecked. qos to xbox is 70% down and up. upgraded cat cable to cat8 26 awg.
Nov 26, 2018Guru - Experienced User
Did you try a factory reset after loading 1.0.1.2 and set up from scratch or what it applied with auto update?
phil_wo wrote:
My router was crashing every 30 minutes on 1.0.1.2. I had to downgrade to 1.0.0.20 to get the router stable. Hoping this issue is resolved with the release of 1.3
phil_wo
Nov 26, 2018Tutor
I never factory reset. I upgraded back to 1.0.1.2 to make sure it was the firmware. Should I factory reset on 1.0.1.2?
