Rickeyjt
Apr 11, 2024Aspirant
XR700 discontinued?
XR700 router B&H showing as no longer available. Is this a soon to be not supported router? Then what to get? I would like the six ethernet ports and wifi combo router.
Apr 11, 2024Guru - Experienced User
Do you have this router or looking to buy?
Theres a beta over on NetDumas site:
NG no longer produces this as new. I've found a couple that were used. Working great.
- RickeyjtApr 11, 2024Aspirant
I ordered the XR1000, only $199. Which has only 4 ethernet ports but I have the GS324 switch already. Three hard wired computers and two hard wired hp printers.
Getting rid of my FVS318G 8 port router and WAC730 access point. The router no longer tech supported - and I need help! Ha . . . thanks!
- FURRYe38Apr 11, 2024Guru - Experienced User
I think the XR1000 will have a beta too.
I enjoy mine when i have it online. đ
Good Luck.
