Misterswede
Feb 28, 2020Guide
Xr700 DNS
Well this one i cant figure out I am getting alot of waiting for response on homepages 300/100 fiber connection I can test a home page works perfect 1ms in oing and then suddenly it stops ti...
- Mar 04, 2020QoS won't be effective like that as your true speeds haven't been input, put your correct speeds in please. It may be you were experience local congestion and due to your settings this wasn't being mitigated.
Misterswede
Mar 04, 2020Guide
Blocked sites are empty
In QoS i have set it to 800 up and 800 down
Then checked antibuffer
The connection is 300 down and 100 up
The slider in QoS i have set to 80% on both
Netduma-Fraser
Mar 04, 2020NetDuma Partner
