Shikwan68
Apr 02, 2019Star
XR700 doesn't see Netgear ProSwitch GS110TP in Device Manager
I have LAG setup between the XR700 and the GS110TP. The router sees all wired devices connected to the GS110TP. The GS110TP has a static IP.
The GS110TP's IP doesn't show up in the XR700's Devi...
- Apr 02, 2019Do you see the individual devices connected to the switch in the device manager? If so then that's normal behaviour.
Netduma-Fraser
Apr 02, 2019NetDuma Partner
- Shikwan68Apr 02, 2019Star
Yes but I thought it was strange as the switch always showed up in the QoS list of my old Netgear R7800 router.
- Netduma_JackApr 03, 2019NetDuma Partner
DumaOS Device Manager works in a different way, so it's not possible currently.
- schumakuApr 03, 2019Guru - Experienced User
This sounds more than poor, sorry.
Hm you want to tell me that a device (GS110TP) with a MAC address (and even an IP address) connected to a port on the DumaOS router switch port can remain stealth to the DUmaOS Device Manager under some conditions?
What are these conditions? E.g. no traffic to the router/default gateway and/or the Internet?
You know what comes into my mind? It starts with a "j" ... sorry saying.
