Haveck
Jul 15, 2021Guide
XR700, Duma 3.0
Well. I am guessing that the XR700 isn't getting anymore updates. 1) Duma 3.0 has been out for awhile now and crickets from Netgear. 2) XR700 is the only gaming router that isn't even listed on t...
- Jul 15, 2021It will be getting updates, we're working on it at the moment. The reason it is no longer listed is because they're no longer being sold/no more stock is being made
Netduma-Fraser
Jul 15, 2021NetDuma Partner
- phishphreakAug 02, 2021Aspirant
Any futher update on the XR700? Ever since the last one my attatched usb drive (Samsung T5) is not detected and I have tried everything I can think of. Rarely does everything on the router all work properly at the same time. I've had issues on and off since the day I bought it.
- Netduma-LiamAug 03, 2021NetDuma Partner
Is the attached drive being used as NAS or are you using it for Plex functionality?
Was it being detected properly in the previous firmware? If so, did you factory reset after upgrading to the new firmware?
- phishphreakAug 03, 2021Aspirant
Yes, the drive is just being used for plex and it has been detected before with no problems. I have tried both ports and nothing. The light will come on on the drive now but nothing. I take it out and plug it into my pc or another pc and detects right away.
