robert27841
Aug 28, 2020Star
XR700 DUMA OS 3.0
When will duma os 3.0 be release date the XR700 Firmware Version 1.0.1.24 - Hot Fix still as some bugs and glitches sometime it doesn't load having to reboot the xr700 often this is ridiculous....
Netduma-Fraser
Aug 29, 2020NetDuma Partner
I responded to you on the Netduma forum but what I said there was:
We don't have a specific release date. It's not available for beta just yet but as soon as it is we'll let people know. If you're having issues I would suggest installing the latest firmware using the TFTP method: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP and then doing a factory reset for the freshest install possible.
- robert27841Aug 31, 2020StarThank you everything works now
