RBosel
Mar 22, 2019Aspirant
XR700 DumaOS Almost Unusable?
Anyone else having issues with their DumaOS being completely useless? Pages take minutes to load and some apps only load after refreshing the page several times. I imagine this is an issue with the l...
Danny80916
Mar 22, 2019Luminary
I posted on the netduma forums they said it was a known issue with the current firmware.
RBosel
Awesome. They fix stability and then the extremely useful OS hits the pooper. Well I am sure my job is easy. I think they have their work cut out for them with the hunk of scrap. I will be holding out until summer for the thing to work as advertised and then I'll be making the jump to another Manufacturer.
- Danny80916Mar 22, 2019Luminary
I am on a diffrent firmware at the moment when I was on .10 mine would load it would just take awhile for them to load everything was able to be used tho.
- Netduma-FraserMar 23, 2019NetDuma PartnerWe have already notified Netgear regarding the issue. Meanwhile I would suggest a factory reset once upgraded and then clear the browser cache/cookies to see if that speeds up the interface.
