ovar0409
Jan 05, 2021Initiate
XR700 DumaOS issue: how to pin again the "Guest status" windows in the Dashboard?
Hi there, I unpined the "Guest Status" view from the Dashboard and as expected it disappeared. But how do you make it visible again in the Dashboard? Stupid stuff, but I cannot see any menu or wh...
- Jan 05, 2021Go to the System Information page on the router, there you will see the Guest wireless panel and you can then re-pin it by clicking the pin icon.
Netduma-Fraser
Jan 05, 2021NetDuma Partner
- ovar0409Jan 06, 2021Initiate
Thanks
